.84 Brick Fix
brick fix ics
6 replies to this topic
#1 knghts50
knghts50
  • 199 posts
  • Google+:kevin.page3
  • LocationCopperas Cove, TX (Fort Hood)
Posted 28 April 2012 - 02:32 PM
I fixed mine using my own method for flash failure and what not. i take no responsibility for further damage.
folow instructions which is in the zip.
#2 eckdawg5
eckdawg5
  • 110 posts
  • Twitter:twitter.com/eckdawg5
Posted 30 April 2012 - 01:08 PM
are you still on .84 or were you able to downgrade? Has anyone tried manual flashing via motoflash?
#3 eckdawg5
eckdawg5
  • 110 posts
Posted 30 April 2012 - 01:09 PM
nevermind, that's what you did...I just DL and read the instructions...
#4 (TSON)
(TSON)
  • 529 posts
Posted 01 May 2012 - 07:21 AM
wrong section...
#5 vikcie
vikcie
Posted 28 June 2012 - 11:42 AM
is this for CDMA because its not working for me..!
m using GSM Asiaretail..?
#6 knghts50
knghts50
  • 199 posts
Posted 29 June 2012 - 05:18 AM
Yes. But copy the cdt file from you sys. And replace it with the one in the folder
#7 vikcie
vikcie
Posted 29 June 2012 - 02:13 PM
Yes. But copy the cdt file from you sys. And replace it with the one in the folder Sent from my DROID RAZR using Tapatalk 2
sorry brother but i didnt got that
can you explain it again..!
i am running on GB 2.3.6
thanks in advance
Also tagged with one or more of these keywords: brick, fix, ics
