R3Ds Themes -=Ikandee-Urban-Ikream-Glassmix And Much More=-
#61
Posted 03 June 2012 - 12:59 PM
#62 Guest_R3Ds_*
Posted 03 June 2012 - 03:48 PM
You very welcome buddy.If you guys like a good stock Rom, your gonna love this along with R3Ds theme. It is very polished and smooth. I have been very grateful for letting me test it. Thanks again R3Ds :-)
R3Ds Themes
#63
Posted 03 June 2012 - 04:00 PM
#64
Posted 03 June 2012 - 04:10 PM
Turn it loose :-)
I know do it ;-)
#65
Posted 03 June 2012 - 06:22 PM
#66 Guest_R3Ds_*
Posted 03 June 2012 - 08:31 PM
URBaN.RaZR.ECLIPSE.1.3.THEME.v2.2-R3Ds
check op for links and info!!!
btw, im going to release the rom in a few minutes.
#67 Guest_R3Ds_*
Posted 03 June 2012 - 09:54 PM
#68
Posted 04 June 2012 - 05:53 AM
#69 Guest_R3Ds_*
Posted 04 June 2012 - 08:43 PM
The urban theme is for eclipse 1.3 rom only.This new theme, can we just flash the theme? Or do we have to install the ROM as well? (181 stock rooted), and another ?.........can we use bootstrap?
R3Ds Themes
#70
Posted 07 June 2012 - 02:31 PM
#72
Posted 08 June 2012 - 12:16 AM
Yep did a wipe, it's not my first rodeo, tired twice, still got stuck at splash screenDid you follow OP instructions about wiping b4 installing theme?
#73
Posted 08 June 2012 - 02:44 AM
#74
Posted 08 June 2012 - 05:40 AM
Fuzz - is where you get stuck on the Dual Core logo or the boot anim & how long do you give it?
I've had some success w/installs that didn't 'settle' (after a few min) that doing the 2 finger Razr salute, i.e. holding
down power & volume down to reboot (in place of battery pull) will sometimes help to get things back on track.
Note that besides putting phone in silent mode, it also sets ringer volume down to about 5-10%
Hope this helps seeker613
#75
Posted 08 June 2012 - 09:28 AM
#76
Posted 08 June 2012 - 12:47 PM
#77 Guest_R3Ds_*
Posted 08 June 2012 - 01:53 PM
I never installed bootstrap, is not needed. I never touch my stock system so I can receive ota. Install safeboot and enable safe system and install all the roms, mods and themes to the second partition. If want to boot back to stock is simple, just disable safe system.The OP says to use safeboot recovery version 1.9. I did not have any luck with flashing the theme. However I could flash the Rom with bootstrap......go figure :-)
R3Ds Themes
#78
Posted 08 June 2012 - 01:54 PM
#79
Posted 22 June 2012 - 10:23 AM
#80 Guest_R3Ds_*
Posted 22 June 2012 - 11:16 AM
Once I finish the mods for ikream ics 211, I will make some themes. Please be patient since I do everything on my own it takes time. Btw GB users I did not forgetCash we bring this over to the new ICS Eclipse Rom. Didn't know if you could port it to ICS.
R3Ds Themes
