R3Ds Themes -=Ikandee-Urban-Ikream-Glassmix And Much More=-
#81
Posted 22 June 2012 - 07:53 PM
#82 Guest_R3Ds_*
Posted 07 July 2012 - 11:14 AM
- Yeag3r24 likes this
#83
Posted 08 July 2012 - 05:38 AM
#84
Posted 08 July 2012 - 06:01 PM
#85
Posted 09 July 2012 - 03:35 AM
Where did you get the clock on ikandee id love to add it too
I think its beautiful widgets
#86 Guest_R3Ds_*
Posted 09 July 2012 - 07:32 AM
- thisismalhotra likes this
#87
Posted 09 July 2012 - 08:57 AM
#88 Guest_R3Ds_*
Posted 10 July 2012 - 02:52 PM
Awesome, thats in eclipse 1.2?I just installed and you are the man!!!! The only issue i had was double texts because this put text messaging on eclipse rom but i just froze it and now we are good.
R3Ds Themes
#89
Posted 11 July 2012 - 03:30 AM
Please keep it up with the good work.
Edit: On arctic right after I installed Urban I'm getting an email app has closed message once or twice and then is gone. I may be the only one. I don't know.
#90
Posted 11 July 2012 - 05:19 AM
Ideas how to have only one?
Thanks guys.
#91
Posted 11 July 2012 - 05:25 AM
Arctic214rv2. Double notification on txt. One white (system) and one orange R3D3.
Thanks guys.
I would use titanium backup to remove one of the messaging apps or you can disable the notifications on one of them. This happened to me too and what it is is that the theme also installs the blur messaging app.
#92
Posted 11 July 2012 - 05:40 AM
#93
Posted 11 July 2012 - 05:57 AM
This post intends to be a constructive one and not a arrogant newbie complaint.
#94 Guest_R3Ds_*
Posted 11 July 2012 - 06:48 AM
The reason of the dupe apps is because artic replaces some blur apps with aosp. My themes are for blur based roms. You can use titanium to remove or freeze. Or you can use theme porter to port the theme to your current rom. I don't mind if is ported.Man I love the colors and icons of Urban but there are problems. The theme installs a full set of duplicate apps like contacts, e-mail, txt etc. These interfere with the good functionality of the OS and I do get FCs (email, google voice) or duplicate notifications (txt and native e-mails). I'm not the one to complain but I'd love to at least be told in the OP what to do with the duplicates. The versions of these apps that come with the theme are older than the ones I have in the ROM (artctic214rv2). Is it better to leave the ROM's ones (newer) or the Urban's ones (older)?
R3Ds Themes
#95 Guest_R3Ds_*
Posted 11 July 2012 - 06:52 AM
R3Ds Themes
#96
Posted 11 July 2012 - 06:55 AM
That's why I posted in op that if you install on deblur roms you will have a lot of problems. R3Ds Themes
#97
Posted 12 July 2012 - 06:56 AM
Question: I want another battery mod (one listed in the OP) am I going to lose the new toggle icons coming from Ikandee?
#98
Posted 12 July 2012 - 07:04 AM
is there any way you can create the siginal status bars multi colored like you had on the GB IKandee theme?
#99
Posted 12 July 2012 - 09:07 AM
#100
Posted 12 July 2012 - 09:45 AM
I did not know you could use this theme with another ROM, is that true?
