Been on XDA for a while and couldn't find the BEATS mod for the RAZR so I signed up here just to search and bang there it is, will be flashing later tonight once I get home.
Glad to hear it!!! Welcome to the forums
Posted 19 June 2012 - 06:18 PM
Posted 19 June 2012 - 06:54 PM
Posted 19 June 2012 - 07:25 PM
Posted 19 June 2012 - 07:40 PM
got it done, somethings worth noting it reboots 3 times and when you get the press any key to continue (that on matts 1.6 would take you back to the main menu) it appears to try to install whatever the next number after the one you just did is. like if you just did the gingerbread it would try to install the ICS.
Posted 19 June 2012 - 08:53 PM
Whoa thanks for that I will fix it ASAP
Posted 19 June 2012 - 09:14 PM
the first reboot showed a motofail (like it was rooting, maybe)
the good thing atleast is that the ICS fails just keeps erroring and won't do anything to gingerbread, so you can't mess it up there.
But thanks for making it super easy to get this MOD that makes it sound so good.
Posted 20 June 2012 - 08:54 AM
Posted 20 June 2012 - 10:09 AM
I have .210 and I kept root when I did it. Which process should I use? Will it even work with .210? I tried just opening the zip and running the Beatshack DOS file and it failed all the way threw.... any help would be appreciated, Thanks
Posted 20 June 2012 - 10:47 AM
Posted 20 June 2012 - 05:55 PM
Posted 20 June 2012 - 09:35 PM
THANKS TO ANDROIDBUDDY, THIS UTILITY RUNS MUCH MORE SMOOTHLY NOW!!!!! DOWNLOAD IT AGAIN IF IT DIDNT WORK FOR YOU BEFORE AND RETRY INSTALLATION
Posted 21 June 2012 - 08:42 AM
Posted 21 June 2012 - 08:48 AM
I'm on rooted 211...... every time I run the utility everything fails & the phone reboots once. Any ideas
Posted 21 June 2012 - 01:31 PM
Posted 21 June 2012 - 01:33 PM
Posted 21 June 2012 - 01:36 PM
Posted 21 June 2012 - 01:58 PM
Posted 21 June 2012 - 03:11 PM
Posted 21 June 2012 - 05:20 PM
Posted 21 June 2012 - 10:10 PM
