Kernel Tweaks For Battery Life/performance
Posted 20 June 2012 - 02:21 PM
POPULAR
ONLY THE PERFORMANCE SCRIPT WILL IMPROVE QUADRANT SCORES! You will see an increase in response time and snappiness.
THESE SCRIPTS WILL BE UPDATED FREQUENTLY!
Last update 7/11
NOTE: Run one script or the other, running both will cause issues in what values get applied.
Latest update notes: Battery life should be beautifully improved with dirty data tweaks for days!
Prerequisites:
Have root access
An app that can run scripts on boot, like Script Manger,located here:
INSTRUCTIONS:
If using Script Manager:
1. Navigate to file.
2.Open as Script/Executable.
3.Set it to run at boot and as Superuser.(SU)
4. Reboot.
Make sure it looks like this: 102.46KB 257 downloads
If using ROM Toolbox:
1. Select "Scripter"
2.Select new script
3. Copy and paste script into Scripter
4. Select "At Boot"
5. Reboot
Make sure it looks like this: 146.57KB 382 downloads
Battery Saver script now in KOA AOKP!
Battery Stats:
150.7KB 440 downloads
140.51KB 304 downloads
I HIGHLY RECOMMEND GETTING THE SIO I/O SCHEDULER AND THE HOTPLUGX GOVERNOR FROM THIS THREAD:
Kernel Tweaks for Performance!
Latest update notes: Latest update notes: enabled ZRAM(compressed RAM), loads SIO I/O if available, also loads the hotplugx governor and SIO on boot. Ups read and write speeds all around, file system speedups, enables multi threading, tweaks to the hotplug and hotplugx governor, and more. You might get random reboots using this script, you might only get a coupke and then they will stop or they'll never stop. Inform me if you consistent random reboots.
Thanks to zeppelinrox for the minfree and adj values.
Thanks to whirleyes for the kernel modules.
You will definitely see an increase in snappiness/response when running this on boot.
Thank you to PureMotive for kernel tweaks to make compatible with this phone, and this thread by him
If you can, please donate:
Or at least leave me a like. Over here >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
- Bmplekan, mattlgroff, Nubia1 and 22 others like this
Posted 20 June 2012 - 02:29 PM
Posted 20 June 2012 - 02:30 PM
Posted 20 June 2012 - 02:31 PM
If you feel the need to buy me a beer, or help pay my bills, here's the link:http://bit.ly/O4ZnLW
Posted 20 June 2012 - 02:33 PM
I'll post it in the OP for some assurance that it works.
Posted 20 June 2012 - 08:10 PM
Posted 20 June 2012 - 08:55 PM
Posted 20 June 2012 - 09:29 PM
Posted 20 June 2012 - 09:32 PM
Download link?
It's in the OP, but here:
Posted 20 June 2012 - 09:40 PM
Posted 20 June 2012 - 09:49 PM
Posted 20 June 2012 - 09:51 PM
Posted 20 June 2012 - 09:56 PM
It's because it has to be run on boot or shortly after boot. None of the values will take if you run it in mid session.So i get this error while trying to run this. Any ideas?
Anyway to check if script worked
You can try going into /sys/proc/vm/dirty_ratio and see if the value is at 90, or try checking any other value and see if it matches up with a script value.
SCRIPT NEWLY UPDATED,LOOK IN THE OP!
Posted 21 June 2012 - 07:00 PM
Enjoy!
Posted 21 June 2012 - 07:03 PM
OP updated with new battery saving script and new script for performance!
Enjoy!
awesome. can u tell us noobs how to run this baby
Posted 21 June 2012 - 07:16 PM
4. Reboot.
2.Select new script
4. Select "At Boot"
5. Reboot
Instruction added to the OP.
- trikotret likes this
Posted 21 June 2012 - 07:18 PM
Posted 21 June 2012 - 07:26 PM
Also added to the OP.
Posted 21 June 2012 - 07:28 PM
No, they contradict each other in values. Run on or the other, do you want performance or battery life? Select one or the other based off what you said.
I am greedy. I like to have both
- BytecodeMe likes this
Posted 21 June 2012 - 07:32 PM
Also tagged with one or more of these keywords: kernel, battery life
