Had a glitch making calls after loading the downloadable file then deleting it. A reboot seems to have fixed it
Hmmm, just made two calls... I don't think those incidents are related.
Posted 28 June 2012 - 08:56 PM
Posted 29 June 2012 - 12:00 AM
Edited by spc_hicks09, 29 June 2012 - 12:00 AM.
Posted 29 June 2012 - 07:03 AM
Posted 29 June 2012 - 07:56 AM
I had the same problem as you spc_hicks. Though I'm using .211 with Simplexrom rc1.1
Dude, that battery saver script made my battery life horrible lol. My phone wasn't even used for 5 of those hours.
Posted 29 June 2012 - 08:14 AM
Posted 29 June 2012 - 08:38 AM
Posted 29 June 2012 - 08:52 AM
Okay, three people means the script definitely needs to change. I'm going to take out and put in a lot of values with this one. In other words, a big updateI am using the downloaded version of the battery saver and am 5 hours with 85% left. No huge use today but been using it off and on. It's not running me down for sure.
Posted 29 June 2012 - 10:04 AM
Posted 29 June 2012 - 11:35 AM
Posted 29 June 2012 - 12:36 PM
Posted 29 June 2012 - 12:44 PM
You didn't do anything wrong. I"m not sure if it's my fault, the file uploaders fault or something that a file goes through on the way, but if you use the downloadable file the formatting gets messed up and that breaks the script. So just use the text, create a new file and paste the text in. Then do everything you've been doing, it'll work then.
Posted 29 June 2012 - 01:37 PM
I don't know what's going on... are you still using the older version of the script? I don't think that would matter, but...I've seen improvement.
Posted 29 June 2012 - 04:15 PM
Posted 29 June 2012 - 05:03 PM
Posted 30 June 2012 - 08:58 AM
Oh, thanks.I apologize that I was not more explicit. I meant that I did not think it was bad. My razr was at 85% after 5 hours. I too use Juice Defender. I did not think that was such a bad battery drain. I was not saying it was killing my battery. 15% after 5 hours does not seem that bad to me on the razr. That would make it on schedule to run roughly a little over 30 hours.
As you're getting error logs on ROM Toolbox, you're missing the last step, just reboot. Then it'll work.When running the performance script (copy-pasta'd from the OP just now), I get this:
I used the updated script, not the download.
I copied all the script into a .txt file
Changed the file extension from .txt to .sh and placed the script on the internal sdcard
Opened script manager, selected the script and select SU and At Boot
The result was what happened in a 9 hour period, my phone was on but completely unused for 5 of those hours. Essentially I only got 4 hours of use out of my phone.
Posted 11 July 2012 - 07:29 PM
Posted 11 July 2012 - 08:06 PM
Posted 12 July 2012 - 04:46 AM
Updated the OP with new versions of both scripts, look at the OP and read AL the new information. Just tell me if any of you want tme to stop updating this thread, I kinow it's a little old.
Posted 12 July 2012 - 06:39 AM
Posted 12 July 2012 - 12:02 PM
