My First Theme
#21
Posted 30 September 2012 - 09:59 AM
#22
Posted 30 September 2012 - 10:35 AM
#23
Posted 30 September 2012 - 03:43 PM
#24
Posted 30 September 2012 - 04:39 PM
Can someone please explain what to do with 9.PNGs? I saw some theming guides say not to mess with them but never saw anything more about them...
#25
Posted 30 September 2012 - 05:11 PM
Eventually you may get to a point when you need to edit the 9 patches.. such as adding a texture to an image that you want stretched throughout the image. When you get to that point you would use the 9patcher tool within the Android SDK and rebuild the guides. But that's another lesson by itself.
#26
Posted 30 September 2012 - 05:39 PM
Ok, I compiled the .apk with ICS Apktool. Not sure how i need to go about making the signed zip file to flash though. I'll try to look for something on it in the morning.
#27
Posted 30 September 2012 - 06:06 PM
Tip: make sure to keep a known working apk on hand on your computer. Should something go wrong such as a bootloop.. you can simply adb push the problem apk back to the appropriate location.
#28
Posted 30 September 2012 - 10:21 PM
I'm compiling what I've got done so far. I'll flash and post screenshots in the morning; I'd really like some feedback.
If you mean you aren't sure how to get a flashable zip then download this
and just put the apk in the appropriate folder. framework-res.apk will go in system/framework and all of the system apps like SystemUI and Contacts will go in system/app
Just a simple drag and drop and then you're ready to flash.
- vtwinbmx likes this
#29
Posted 01 October 2012 - 01:09 AM
I put SystemUI in the app folder, and I moved the framework-res.apk from ICSapktool to the framework folder. I used 7 zip to compress into a zip, but when I tried to flash, it went to "Installing update..." and stopped. It showed Installation aborted.
#30
Posted 01 October 2012 - 01:28 AM
You need to make it flash able. Inside the zip should be META INF and system. In system/app/ put systemUI and in system/framework/ put framework-res.apk. meta inf houses the updater script. It needs to mount system, extract files from system, and unmount system. See how roms and themes out there do this for a model.I put SystemUI in the app folder, and I moved the framework-res.apk from ICSapktool to the framework folder. I used 7 zip to compress into a zip, but when I tried to flash, it went to "Installing update..." and stopped. It showed Installation aborted.
Sent from my MB860 using Tapatalk 2
#31
Posted 01 October 2012 - 01:29 AM
#32
Posted 01 October 2012 - 02:42 AM
-=(.stryker.originals.)=-
#33
Posted 01 October 2012 - 04:33 AM
I think I screwed up the updater-script when I was taking out some text I added. That may have been the problem. Download this zip and try this one.
Also are you pulling framework-res straight out of the dist folder when you compile it? If so then you are missing a step. You have to open the apk in the dist folder and the original unmodified apk on your desktop in 7zip so they are side by side on the screen. Then drag-n-drop the folders you modified from the one that opened from the dist folder to the one that you opened from the desktop. If you made any xml edits then you will need to move the resources.arsc file too.
#34
Posted 01 October 2012 - 04:42 AM
Dude it takes me months to do a full miui or theme engine theme. That's making most of it scratch, and maybe 30 percent color edit stuff and xml. It's a pain!!! I can knock out a go launcher theme in 2 weekends if i get both days off. But usually i get an hour a day or a couple on the weekends. I wish i had more time so i can pump out more themes. I just don't. I'm sure other dev themers can relate that have other full time jobs.
Yeah! Full time job sucks! But a mans gotta eat... lol. I feel your pain.
#35
Posted 01 October 2012 - 06:08 AM
#36 Guest_24v_*
Posted 01 October 2012 - 10:46 AM
LOL, try 4 hours.Or pull a 24v and do an entire theme in like 8 hours without break.
Batching FTW.
In all fairness, I wasn't creating anything on those themes, just color changes, and a few small mods here and there.
- HouseMD likes this
#37
Posted 01 October 2012 - 11:37 AM
+1Yeah! Full time job sucks! But a mans gotta eat... lol. I feel your pain.
#38
Posted 01 October 2012 - 04:39 PM
Well here goes....
#39
Posted 01 October 2012 - 04:41 PM
LOL, try 4 hours.
Batching FTW.
4 hours? And I thought Alice was crazy for doing one in 10 hours...
#40
Posted 01 October 2012 - 04:46 PM
We're all a little bit crazy around here.
