My First Theme
#41
Posted 01 October 2012 - 05:31 PM
Installing update...
Installation aborted.
Not sure what I may have missed in this process. Do I need to make changes to any of the other files in the folder before I compress it into a flashable zip?
And of course, I clear cache / data before I try to flash...
#42
Posted 01 October 2012 - 05:43 PM
#43
Posted 02 October 2012 - 12:48 AM
5.63MB 8 downloads
#44
Posted 02 October 2012 - 02:16 AM
But it looks like you didn't use the add to archive in 7-zip
#45
Posted 02 October 2012 - 02:22 AM
- usmcamgrimm likes this
#46
Posted 02 October 2012 - 04:59 AM
Adb remount
Adb push SystemUI.apk /system/app/SystemUI.apk
Just make sure you are copying your changes from the compiled apk to an original or resigning the new apk. That is extremely important! Failure to do so could cause signature mismatch issues which will lead to the system to ignore it.
- vtwinbmx likes this
#47
Posted 02 October 2012 - 05:39 AM
But hey, themeing is a PITA. Gotta work for what you want though!
If you feel the need to buy me a beer, or help pay my bills, here's the link:http://bit.ly/O4ZnLW
#48
Posted 02 October 2012 - 03:50 PM
Fyi.. for testing purposes like what it sounds like you're doing... adb is your friend! Much less time consuming.. Adb remount Adb push SystemUI.apk /system/app/SystemUI.apk Just make sure you are copying your changes from the compiled apk to an original or resigning the new apk. That is extremely important! Failure to do so could cause signature mismatch issues which will lead to the system to ignore it. Sent from my DROID RAZR using Tapatalk 2
I haven't really used adb much; seems faster than swapping the files over with dropbox though
#49
Posted 02 October 2012 - 05:11 PM
Ok that was the problem, you need too use the add to archive when zipping your theme, Here is you theme using add to archive ready to flash, You can use my META-INF if you wish that I used on this test for you it auto wipes cache and delvik, Good luck Ohio brother don't give up you almost there
I haven't had a chance to try it again on my pc, but I'll give it a go in the morning and report back. I tried the one you posted though and it flashed, so if that's all you had to do I shouldn't have any problems.
I do see, however that there are some changes / fixes that need to be made. And i thought i had done more than what I can see. It's nice to see what I'm doing though...makes me want to get it done!
#50
Posted 02 October 2012 - 05:37 PM
#51
Posted 04 October 2012 - 05:19 PM
If I can't get a zip made that will flash, would I adb work to push it to the phone?
Well, in an unexpected turn of events, I finally got it to flash! Unfortunately, I don't know how. All I did was copy over the new SystemUI.apk into the folders and then add to archive with 7zip., Instead of starting from scratch. Whatever works, I suppose....
Edited by usmcamgrimm, 04 October 2012 - 05:25 PM.
#52
Posted 04 October 2012 - 06:32 PM
#53
Posted 05 October 2012 - 01:33 AM
I was adding usmcamgrimm.theme to the archive, instead of just the folders inside, so it created an extra folder in the archive that was unreadable. I fixed the error, and now am able to flash my zips. Now that I know that process, I'll start using adb....
Hopefully I can get some screenshots up in the next day or 2....
#54
Posted 06 October 2012 - 08:36 AM
#55
Posted 07 October 2012 - 06:41 AM
Dumb question...is there any way possible to change a color as a batch operation or do i need to edit each file individually?
Of course you can! I do it all the time. I use Photoshop CS6 to do it though and I'm not sure of other programs have the capability.
#56
Posted 07 October 2012 - 07:21 AM
You can try GIMP if you don't have Photoshop. It's pretty dynamic, but I'm basically illiterate when it comes to anything ending in -er or -or (vector, raster, etc)! So you'll have to read the features yourself to see if it will do what you need. I've used it to paste photo layers, but that's all...
www.gimp.org
Sent from my DROID SPYDER using Xparent Blue Tapatalk 2
#57
Posted 07 October 2012 - 08:38 AM
#58
Posted 07 October 2012 - 08:44 AM
I didn't see an option like that in Paint.net, so I spent a few hours last night changing them manually. And when i realized that I need to check the new colors on my phone's screen, I made a new apk and when I flashed it, both my nav bar and status bar were gone. I don't know how that happened, but I was falling asleep while working on so that might have had something to do with it....
That happened to me a lot and I found it to be an xml error, were you messing with the xml or just .pngs?
#59
Posted 07 October 2012 - 09:09 AM
#60
Posted 07 October 2012 - 09:15 AM
It was like 4 am when I was messing with it last night so I probably just overlooked something when I was doing it.
There is a wealth of info that I've found on this by looking through google. Sometimes it's hard to sift through it to find exactly what I'm looking for. My problem is patience though. I have none! lol
