HD having issues
104 replies to this topic
#41 SamuriHL
  • 43,461 posts
Posted 06 July 2014 - 03:47 PM
It's different.  Use that command then boot.
#42 Plague
Plague
  • 40 posts
  • LocationTennessee
  • Current Device(s):Droid Razr HD xt926
Posted 06 July 2014 - 03:50 PM
Ok did that, here is the output from my cmd line, rebooting my phone now.
#43 SamuriHL
  • 43,461 posts
Posted 06 July 2014 - 03:52 PM
I'm not sure that was 100% successful.  Wonder if the HD supports it.
#44 Plague
Plague
  • 40 posts
  • LocationTennessee
Posted 06 July 2014 - 03:53 PM
:( Still same thing when it boots up
#45 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
  • LocationWhere I AM
Posted 06 July 2014 - 03:54 PM
looks like it did it from what i can tell
#46 SamuriHL
  • 43,461 posts
Posted 06 July 2014 - 03:55 PM
No, it erased cache and userdata but doesn't look like it erased internal mem.  I'm not sure on the HD you can do so without booting.  I don't think there's a lot more that can be done.
#47 Plague
Plague
  • 40 posts
  • LocationTennessee
Posted 06 July 2014 - 03:59 PM
Does that mean you think it's something wrong with the hardware itself?
#48 SamuriHL
  • 43,461 posts
Posted 06 July 2014 - 04:08 PM
Well, he thinks there's something wrong with the internal memory which is causing it not to boot correctly.  I'd say that's entirely possible. Neither of us know how to fix the internal memory problem.  So......there's that.
#49 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Worked fine for me
are you using the snapdragon fastboot or the fastboot that comes with the sdk?
#50 SamuriHL
  • 43,461 posts
Posted 06 July 2014 - 04:10 PM
Hmmm.  Wonder if it's the fastboot binary that matters....as in it must be the platform tools version.
#51 Plague
Plague
  • 40 posts
  • LocationTennessee
Posted 06 July 2014 - 04:13 PM
Been using the SDK one, but I do have the Snapdragon one as well loaded in my HoM in the FXZ dir.
#52 SamuriHL
  • 43,461 posts
Posted 06 July 2014 - 04:14 PM
Try the moto version.  And make sure the platform tools one is updated.
#53 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
There is a issue on doing this.... It will format the internal storage completely and it would need to get reformatted.... Had to format in TWRP to gain control back. I bet that his internal storage is not accessible because it is in a RAW state and not ext4 where it needs to be.
#54 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 06 July 2014 - 04:18 PM
Yeah I replaced the ones in the platform tools with the snapdragon ones from HOM. The only way I could open command window was in that folder.
#55 Plague
Plague
  • 40 posts
  • LocationTennessee
when I just used the snapdragon version, my output looked exactly like yours.... should I mabe replace my sdk files with the snapdragon files then try to re HoM it?
#56 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 06 July 2014 - 04:27 PM
Wouldn't hurt.... You might need to fastboot the 183 yet one more time with HOM or RSD so that the internal storage gets formatted to the updated f2fs format.
I just .bak the ones that came with the sdk just to keep them on the side. Then copy the snapdragon version over to platform tools.
#57 SamuriHL
  • 43,461 posts
Posted 06 July 2014 - 04:30 PM
Well that would have been good to know.  LMAO
  • nobe1976 likes this
#58 SamuriHL
  • 43,461 posts
Posted 06 July 2014 - 04:31 PM
Yes, reflash the FXZ.  Using FULL.
#59 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Remember Sam I use Linux Mint 98% of the time. LOL
#60 SamuriHL
  • 43,461 posts
Posted 06 July 2014 - 04:32 PM
NO excuse!  :p  LMAO
