HD having issues
104 replies to this topic
#61 Plague
Plague
  • 40 posts
  • LocationTennessee
  • Current Device(s):Droid Razr HD xt926
Posted 06 July 2014 - 04:44 PM
No go, still same :(  it did say google search stopped, which it does sometimes it will pop up saying it stops. Also Google Play services has stopped, just randomly.
#62 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
  • LocationWhere I AM
Posted 06 July 2014 - 04:50 PM
OK now boot into stock recovery and fdr from there.....
#63 Plague
Plague
  • 40 posts
  • LocationTennessee
Posted 06 July 2014 - 05:03 PM
Did that, still no go.
#64 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 06 July 2014 - 05:13 PM
When you installed the 183 pkg did it boot into recovery mode after the completion of the flash or did it just boot into the system. I think RSD flashing makes it complete the rest in recovery, but I am not sure. I know HOM doesn't, use it all the time.
#65 SamuriHL
  • 43,461 posts
Posted 06 July 2014 - 05:16 PM
Nope, it doesn't go to recovery. The bionic did way back when because it had to finish the radio crap, but, the HD/M don't do that.
#66 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 06 July 2014 - 05:21 PM
Ah the locked up tighter then a seals A$$ Bionic... Those were the good days.....
#67 Plague
Plague
  • 40 posts
  • LocationTennessee
Posted 06 July 2014 - 05:22 PM
Yea Sam is right, when it's done flashing, HoM or RSD it just reboots and goes straight into normal boot.
#68 SamuriHL
  • 43,461 posts
Posted 06 July 2014 - 05:29 PM
It's fubar IMO.  I don't know what else can be done.
#69 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 06 July 2014 - 05:32 PM
Wasn't there somethng about having to go back into stock recovery a second time manually and start the flashing again?
#70 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 06 July 2014 - 05:35 PM
How long does it usually take when the phone reboots. I wonder if in the state that it is in that one can get towel root done in time to root then just unlock it through the PC version
#71 SamuriHL
  • 43,461 posts
Posted 06 July 2014 - 05:36 PM
PC version requires it to be in adb debug mode, not fastboot.  Won't help.
#72 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 06 July 2014 - 05:38 PM
That was on the 182 update Sam put together which the OP can try to restore it back to that state, but I think for some reason or another that the internal storage is still not formatting to the new format. Freaking Moto why change something that isn't broken.... Argggggh
#73 Plague
Plague
  • 40 posts
  • LocationTennessee
Posted 06 July 2014 - 05:40 PM
Unfortunatly, I can't even get my google email info put in before it locks.  I've tried to find the fxz for the 182 so I could try that, but I can't seem to locate it. A little while ago I tried to brick it lmao, I flashed, 9.30, it wouldn't boot, and recovery was useless, so I just fastbooted 183 back on, nothing changed lol
#74 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 06 July 2014 - 06:15 PM
I have the original ota zip here for both jumps 9.18.79 and 9.30.1
#75 SamuriHL
  • 43,461 posts
Posted 06 July 2014 - 06:25 PM
And what will that do?
#76 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 06 July 2014 - 06:28 PM
Just about tried everything else.  Didn't know if the ota had anything different it it for converting partitions.
#77 SamuriHL
  • 43,461 posts
Posted 06 July 2014 - 06:29 PM
The ota isn't going to do anything since he can't downgrade.
#78 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 06 July 2014 - 06:31 PM
These are the ones that jumped from the two 9. versions to kitkat.
9.18.94 to 182 and 98.30.1 to 183.  Just a thought. Forgot he was locked.
#79 Plague
Plague
  • 40 posts
  • LocationTennessee
Posted 06 July 2014 - 06:49 PM
Yea unfortunatly, if it wasn't locked, downgrading would be easy to try :(
#80 SamuriHL
  • 43,461 posts
Posted 06 July 2014 - 06:52 PM
I don't really have any other ideas.
