Jellybeans! DROID RAZR HD Verizon New Leak and Atrix HD AT&T Firmware(FXZ)!
#41
Posted 30 November 2012 - 10:03 AM
#42
Posted 30 November 2012 - 10:42 AM
Fails on build.prop blah blah blah.
Guess I will have to use the trusty ol Utility again.
#43
Posted 30 November 2012 - 10:59 AM
#44
Posted 30 November 2012 - 11:09 AM
#45
Posted 30 November 2012 - 11:12 AM
So I can't get the install to go thru from the previous leak.
Yeah you have to be on stock ICS to flash this.
#46
Posted 30 November 2012 - 11:19 AM
( typed "into your tool" at first............ then I thought better of it............. )
Proud father of a US Marine
#47
Posted 30 November 2012 - 11:26 AM
Matt, is this something you would bake into your utility?
Leave his 'tool' alone. That was painless to update.
#48
Posted 30 November 2012 - 12:02 PM
I updated the Super User app and binaries (as well as checked the OTA Root survival option [my issue?]) and backed up root with VooDoo Root Keeper as well and after flashing this, I go to restore root from VooDoo and it says it restored it, but I have NO ROOT???? What gives?
Anyone know a sure fire step by step what you did to keep root?
#49
Posted 30 November 2012 - 12:05 PM
Does anyone confirm that root keeper kept root?
Did you go back to stock from Matt's Utlity? If so, did you update the Stock OTA? I lost root once and figured this was probably the cause. (i.e. I restarted the process and insured I took the update...... and it worked).
#50
Posted 30 November 2012 - 12:10 PM
I can confirm that Root Keeper worked just fine with the update. Sorry to say but your only option to regain root is to start over again.
#51
Posted 30 November 2012 - 12:22 PM
Thanks y'all
#52
Posted 30 November 2012 - 01:26 PM
Just be sure to temp unroot before installing the latest build.
#53
Posted 30 November 2012 - 02:12 PM
#54
Posted 30 November 2012 - 02:21 PM
Yeah, I've already accepted that I'll have to start over, just not sure why root wasn't kept, I'll skip the option in Super User and just use Voodoo and see if that works.
Thanks y'all
It's always been finicky. Make sure you've updated the binaries to be current before you back it up.
#55
Posted 30 November 2012 - 02:22 PM
Seems odd that some theming is absent on this build.
It's not so much missing as they just are themeing less and less because people want a more vanilla experience. I just wish the stock apps had the "dark mode" option like the corporate email does.
#56
Posted 30 November 2012 - 02:34 PM
#57
Posted 30 November 2012 - 04:48 PM
#58
Posted 30 November 2012 - 05:03 PM
so I am going to assume that the soak test has already begun since verizon has already approved the update
I believe the soak is already out, yes
Sent from my DROID RAZR M using Tapatalk 2
#59
Posted 30 November 2012 - 05:07 PM
Thanks to all involved for this! It is appreciated.
#60
Posted 30 November 2012 - 05:46 PM
But getting back to the battery, it is simply a slightly different color than the signal bars and clock..
