Jellybeans! DROID RAZR HD Verizon New Leak and Atrix HD AT&T Firmware(FXZ)!
#61
Posted 30 November 2012 - 05:57 PM
#62
Posted 30 November 2012 - 06:27 PM
Where am I going wrong?
Thanks!
#63
Posted 30 November 2012 - 06:37 PM
One last question...I am flashing this in stock recovery, right? Just want to be sure.
#64
Posted 30 November 2012 - 07:21 PM
failed to verify signature and I am bone stock other than root
#65
Posted 30 November 2012 - 07:35 PM
ok again ist says failed to verify whole file signature
Is it failing to verify the file or while verifying system?
#66
Posted 30 November 2012 - 07:38 PM
Since I am on the JB leak using SafeStrap...I will have to SBF back to stock, install the update and then recreate any rom slots I want? I also have to use Root Keeper for root. Did I leave anything out?
Flash Stock, update small update, root, update binaries, backup root and then flash in stock recovery. Then you can reinstall ss and recreate slots.
- natedogg11 likes this
#67
Good luck
#68
Posted 30 November 2012 - 07:40 PM
Thank you...gonna give it a go.
#69
Posted 30 November 2012 - 07:41 PM
#70
Posted 30 November 2012 - 07:51 PM
the file
OK, delete your current file and redownload it. Sounds like you got a bad download.
#71
Posted 30 November 2012 - 08:04 PM
#72
Posted 30 November 2012 - 08:37 PM
#73
Posted 30 November 2012 - 09:08 PM
Edit: Scratch that...just needed to update Superuser. Duh!!
#74
Posted 30 November 2012 - 09:51 PM
BigDX theme is still a go for this new JB OTA
What did you use to create your ROM slot? The file Hash gave us in the SS thread? Just curious bc I don't think we can flash this as a base (or I don't know how to).
#75
Posted 01 December 2012 - 01:30 AM
#76
Posted 01 December 2012 - 02:55 AM
#77
Posted 01 December 2012 - 07:12 AM
Rerun it and pay attention to what the utility is doing. I am pretty sure you missed a step in that utility.
#78
Posted 01 December 2012 - 08:04 AM
#79
Posted 01 December 2012 - 08:23 AM
#80
Posted 01 December 2012 - 09:07 AM
Hmmm... looks like the option to adjust "Audio Effects" in the Settings >> Sounds is no longer available. Don't remember if this was in the older leak or not, but just noticed it now.
It seems to be only in apps now like Google Play Music or Spotify. I found it in Spotify under "Audio effects" and in Play music under "equalizer" I believe. I am unsure if it works across the board or in just apps that have access to it.
