4.3.3 Works like a charm. For the sake of argument I would've liked to figure it out... The new version picked up the LTE and APNs right off the bat. Made sure to test this time... amazing this one's even faster than 4.2.2 Like a new phone every time. Thanks for all your hard work. Can't wait to enjoy this on the run. Had flashed back to stock first and found the Preferred Net Mode was set to Global. Upgraded to 4.3.3 since I was in and out of recovery already. That may have been an issue as well if anyone else has the same glitches on VW. Didn't even have to hit the apns-conf.xml this time. You rock cj, can't wait to see whats next... keep DEV'n.
#101
Posted 13 September 2013 - 03:24 PM
- cj360 likes this
#102
Posted 16 September 2013 - 07:24 PM
Next update coming soon now that pa's updated with some new fix & stuff it'll also be built with 4.8 toolchain! whoo! I'm probably the few that are glad pa hasn't updated till recently cause these toolchains have been a beotch.
#103
Posted 17 September 2013 - 11:04 AM
Removed 4.2 builds as 4.3 is now rock solid, and I hope to have a new update out soon.
- shane1, bigdanmeys13 and bjoostema1933 like this
#104
Posted 17 September 2013 - 02:56 PM
What's gonna be in the new update? Currently on 20130902 build i believe. I kill battery if i don't run ondemand or powersave :-/ msm-dcvs flies, though. Trade off i suppose. So far everything is good except loading custom fonts in ROM toolbox renders boot fail... even after wipe cache... something to do with odex? Worked ok in 4.2.2 not that its all that important. Rather have LTE and MMS so I'm good. Other than that seems rock solid in all my testing. No FCs so far. Very pleased. Amazing job.
- cj360 likes this
#105
Posted 20 September 2013 - 06:31 AM
Not that much of an update, pa upted to 3.99-rc-1 but its just a few new additions. I'm trying to build with sabermod's 4.8 toolchain and it'll be really optimized, if I can figure out the warnings and errors it keeps throwing out.
- bigdanmeys13 likes this
#106
Posted 20 September 2013 - 09:40 AM
- cj360 likes this
#107
Posted 20 September 2013 - 05:09 PM
That would be cause the torch apk isn't included. I'll remeber to add it and c-lock as I like it on carbon.
- bjoostema1933 likes this
#108
Posted 21 September 2013 - 01:55 PM
Well, if it gets any faster it'll be an amazing feat... Yeah I noticed the torch in QS panel and the flash in the stock camera isn't working, but the flash in focal is fine and my power toggles hit the torch so no big deal. After daily driving I have had a few random reboots when playing Plague Inc and a few 30 second hangs when trying to go into recent apps. Other than that no issues. If I'm not mistaken, didn't 4.2.2 have the CPU options and everything right in the settings to change the I/O and processor throttle? I didn't see it in 4.3.3. I only ask cause RomToolbox has been pissing me off lately. FCs sometimes. Maybe a fresh install... What's up with the PA OTA update thing? I'm guessing it should be avoided...? And with the updates to 4.3 I can just flash and clear cache, right? No wipes? I haven't done any updating with other ROMs I've had... Thanks
#109
Posted 21 September 2013 - 04:00 PM
I added in the cpu options in 4.2 I might add them back to 4.3. The OTA server is down as pa is still in progress with moving their seever and its still down. Or in the process of moving.
#110
Posted 21 September 2013 - 05:07 PM
OK, sweet. Thanks for the work. Keep us postedddd.
#111
Posted 25 September 2013 - 04:50 PM
Saw you have a new build up. Is this one good to go? Can I just flash this over the 0902 build? Never had ROM updates to install...
P.S. jaybob413 has some $
#112
Posted 26 September 2013 - 02:49 AM
Nope don't use rc-1. Issues with the kernel make it freeze on boot ani. hoping to whip up another one that's fixed.
Don't use RC-2 either! THat also sticks on the boot ani. Hopefully 3rd time's the charm.
#113
Posted 02 October 2013 - 06:43 AM
Re-did op cause of reasons. And RC-2 is stable for everyone! Or at least it should be on each of the motorola devices I've built for.
- kamaromike and bjoostema1933 like this
#114
Posted 02 October 2013 - 07:09 AM
Been running your latest build for about 24 hours and it is truly stable! Much appreciation for your work man, I have actually found a rom I'm sticking with seriously, not a single hiccup!
- cj360 likes this
#115
Posted 02 October 2013 - 07:27 AM
Thanks again.
#116
Posted 02 October 2013 - 08:40 AM
I'm almost always going to recommend to start fresh, there's multiple apps you can get to backup your import data or do it manually. And it'll save you from whatever bugs a dirty flash could cause.
#117
Posted 02 October 2013 - 09:09 AM
Also tagged with one or more of these keywords: ParanoidAndroid, razr, hd, Linaro
