The first to in the updater script, both lines will say assert in them unless I removed them before I uploaded the final package.
#61
Posted 16 August 2013 - 06:17 PM
#62
Posted 17 August 2013 - 06:30 AM
Downloaded 8/16 build. Those assert lines aren't there. Still won't flash. Downloaded older versions, removed asserts, still won't flash. Can't find an option in twrp to disable md5 check for installing, just backup. I have no clue... I have to be missing something.The first to in the updater script, both lines will say assert in them unless I removed them before I uploaded the final package.
Sent from my Razr HD using Tapatalk 2
#63
Posted 17 August 2013 - 12:58 PM
I would say try on twrp 2.5 as I can't replicate the issue.
#64
Posted 17 August 2013 - 05:35 PM
Tried on 2.5 first. Didn't flash, so re-read your thread & saw you said update recovery. I've tried on TWRP 2.5, 2.6, and cwm.I would say try on twrp 2.5 as I can't replicate the issue.
#65
Posted 17 August 2013 - 07:57 PM
What's your antivirus? Maybe you have corrupt downloads? Idk man
#66
Posted 17 August 2013 - 08:51 PM
Help!! I've tried flashing every possible version of PA I can find for xt926. EVERY ONE OF THEM hangs when flashing. "Checking md5sum. Skipping md5 check. No md5 file found." Then nothing. I've tried every possible (I think) mount/don't mount, wipe/don't wipe combo. I'm on a RAZR Maxx HD, rooted, unlocked, running Vanilla Rootbox.
I know that system has to be mounted for most stock roms, but it needs to remain unmounted for for aosp rom flashes. I don't know if this helps any, but hey... I'm on the toilet and figured I'd try to do something constructive.
Sent from my XT926 using Tapatalk 4
- pazuzuftw likes this
#67
Posted 18 August 2013 - 06:11 AM
#68
Posted 18 August 2013 - 12:20 PM
- bigdanmeys13 likes this
#69
Posted 18 August 2013 - 12:21 PM
- TeamRage likes this
#70
Posted 18 August 2013 - 12:51 PM
Really? I didn't know that, maybe that's why when I tried flashing the xenonhd rom it kept failing. Thanks for that info though, I was under the impression you always had to mount system. When I wipe before my next flash should I also wipe system since I've been mounting it?
#71
Posted 18 August 2013 - 01:04 PM
I don't think wiping system is necessary. I also don't know the reasons for having to mount or unmount for different rom versions, I just saw someone else mention it and it seems to hold true.
#72
Posted 18 August 2013 - 01:15 PM
I've noticed that the overflow settings button is missing from several apps (gallery, play store, etc...). I can easily permanently add the menu button to the navbar as a solution, but there is usually a setting somewhere to force the in-app settings overflow button... am I missing this setting somewhere? (On PA 3.69 8/16)
#73
Posted 19 August 2013 - 09:26 AM
It may have been removed, I'm not sure as just tend to not use it.
#74
Posted 20 August 2013 - 12:07 PM
cj360, you should be proud of the stability and battery life of this rom. It's really great!
- cj360 likes this
#75
Posted 20 August 2013 - 12:13 PM
Would someone toss up a working link, please
#76
Posted 20 August 2013 - 12:17 PM
Delete the last bit from the urlWould someone toss up a working link, please
#77
Posted 20 August 2013 - 12:25 PM
Modified the link to take you to CJ's folder - Be sure to navigate to the proper device.
- cj360 likes this
Sig by
#78
Posted 20 August 2013 - 01:38 PM
you guys are awesome, thank you! I love the community behind this phone
- cj360 likes this
#79
Posted 20 August 2013 - 02:54 PM
PSA: Don't download the 4.3 version of the rom in the download folder. It's not finished yet AKA It won't boot.
#80
Posted 21 August 2013 - 01:12 AM
Unless I say otherwise the 4.3 builds are present alpha especially since ATM its a battle to get it to boot or when it does its full of FCS.
Also tagged with one or more of these keywords: ParanoidAndroid, razr, hd, Linaro
