Could you send me the image(s) for the battery icons? I might just try to stretch out those numbers a bit, replace the font or such.. Or ask a more photoshop inclined friend to help. Everything else looks great, but the battery icon is just a tad illegible, at least to me.Haha, I'm just glad there isn't a problem if you do end up making an icon and want a hand putting it on then let me know and I'll be glad to help
#41
Posted 13 December 2012 - 02:26 PM
#42
Posted 13 December 2012 - 03:44 PM
The files are in SystemUI.apk. You'll find them there. I don't think changing the font will be an easy task. The image is one picture which means the font is not selectable. If you find a way to do it, then great! My suggestion would be to start from scratch with a 38x38 transparent png and get creative
#43
Posted 30 December 2012 - 01:16 AM
Sent from the DAD of all S2s - The Epic Touch.
#44
Posted 30 December 2012 - 04:48 AM
i am disappointed that there are just two likes for such a refreshing theme
keep the great work up mate
EDIT : ZK : how about a stock zip as well , in case someone wants to revert to stock flick looks ? would be handy
#45
Posted 30 December 2012 - 09:18 AM
This is fantastic
That's a good idea. I didn't think of it, but I'll keep it in mind for the future. I always make a back up before I flash a theme so I can always revert back.
#46
Posted 07 January 2013 - 09:52 PM
#47
Posted 08 January 2013 - 05:27 AM
is there another link for the icon packs? really need them.. all looks great, except the blue facebook icon....uhg....
Are you using a computer to download the icons? The link seems to be working. Try that and if you are having problems I'll upload another set
#48
Posted 08 January 2013 - 10:49 AM
yes sir, getting file blocked for violation from mediafire..
#49
Posted 08 January 2013 - 11:03 AM
Ok, it's because there is an icon called ttorrent. The mediafire system sometimes flags the file because it has the word "torrent" I removed that icon, so now it should work
Here you go:
- phrite likes this
#50
Posted 08 January 2013 - 12:49 PM
Also tagged with one or more of these keywords: Flick, Theme, Wood
