Do we know yet if our errors are bootloader version related or system version related or what?
I seem to remember that p3 reverted the system for the bionic so that a fastboot was possible... but was the bionic's bootloader unchanged? I can't seem to remember...
My thought is simple. If it's a bootloader incompatibility, we're in for a tough or impossible fix. But if it's a system incompatibility, then all we need to do is successfully change our system to 173 or 181. And for that we would just need to get a GB system to run on an ICS kernel. Basically the opposite of what STS dev has been doing. Possible?
It probably wouldn't work for RSD but might for a manual CLI process.
Thoughts?
[ 43V3R IC3'd on .84 ]
Getting back to the Bionic, the problem was that the bootloader had changed. That's why I sent mine to Motorola, I would have paid but I guess they gave me a break because my phone wan't rooted it was just updated with the incorrect file back when there were 2 identically named updates that resulted in two different versions after flashing, one kept the upgrade path valid and the other didn't. But P3 did figure it out, if I had been patient I could have fixed it myself. Still, $110 is still cheaper than you's find a non contract RAZR or MAXX that is fully functional and loaded with the correct ROM. That's what I would do because that keeps VZW and Assurian out of the picture.
