what browser u guys using? chrome on my phone and pc worked np
I was using Dolphin on my phone, tried Chrome on my phone and that didn't work, but it came up fine on Chrome on my PC. Thanks.
Posted 21 July 2013 - 09:38 AM
Posted 21 July 2013 - 05:43 PM
--- Update [2013-07-21]pulled in latest aospa patches and some personal touches, instead of cm's privacy guard I included from ChaOS permissions' manager allowing individual control of each app's allowed permissions. Uploaded latest builds for both cdma and gsm variants.Only two things I've noticed:~ I somehow broke halo colors, I'll fix that in the next build~ Gps icon stays in statusbar once you get a lock, disappears after you reboot. Not a functionality issue just kinda annoying imo.And just putting this out there, these builds will stay close to aospa but have a few changes from me
Posted 23 July 2013 - 09:17 AM
Posted 23 July 2013 - 10:00 AM
Posted 23 July 2013 - 10:14 AM
Its working fine here on stock browser, on eailer pa build since I haven't had time to setup on a newer one.
Posted 24 July 2013 - 07:52 AM
I got it I went over to xda to your thread and it worked there doesn't make sense really but I got it. Does it have the security patches and is the bluetooth issue fixed?
Sent from my Razr HD using Tapatalk 2
Posted 03 August 2013 - 03:16 PM
New build is up:
just xt926 for now, 925 has just started to build.
I don't think I'll be starting a jb3 (4.3) build anytime soon as it will need a lot of fixes so I'll probably start that once I finish my summer job and night class at college. So hopefully in a couple weeks there will be some non google device builds of pa too.
Edit- if the zip doesn't flash or fails to open the zip and go to /META-INF/com/google/android/ and open the updater-script with notepad or gedit and remove
also xt925 is up
another edit--
a new build for 926 is up, this has a ton of new f%$ks and LINARO so it will fly faster than before (though I thought it was pretty fast be4 )
Posted 05 August 2013 - 05:32 AM
Posted 06 August 2013 - 12:36 PM
Check to make sure your have your apn selected, it doesn't like to do it for you for whatever reason.
Posted 06 August 2013 - 08:02 PM
Is there anything special we need to do to get the tethering working? It is giving me a fair bit of trouble, aside from that I am overjoyed to finally have this ROM on our device and would like to make it a daily driver If this issue can be fixed.
Posted 07 August 2013 - 07:09 AM
Posted 09 August 2013 - 01:14 PM
About to give this a try right now, with the led colors I've found on aokp and cm that the same hex values will work and once I've flashed I'll try those out and post them in case anyone was having too much trouble with them.
Posted 15 August 2013 - 11:09 AM
Started work on pa4.3 but I'm stuck here :
Posted 16 August 2013 - 04:07 AM
Link is broken
Posted 16 August 2013 - 08:02 AM
I'm having the same problem MajesticMint is having with the wifi tethering. I would use CWM tether, but I don't want just USB tethering. The native wifi tether freezes on "Turning hotspot on..." as shown in screenshot. I've also tried wifi_tether_v3.2_pre2, which has worked on previous AOKP based installs. Anyone else able to get wifi tether to work on PA? I'd really like to have this as a daily driver, but wifi tether is a critical function for my needs.
Posted 16 August 2013 - 08:14 AM
Posted 16 August 2013 - 03:24 PM
Posted 16 August 2013 - 03:31 PM
Which recovery are u using? Have you set it in options to ignore md5 on install, cause you should.
I use twrp v2.5 on my xt926 and it installs fine, unless I forget to remove the assert lines at the top, which I have from time to time.
Posted 16 August 2013 - 04:48 PM
